Steel Frame Modeling in Sap 2000
Hi
I used Sap 2000 v14 for steel modeling .
I modeled a 7 story building .The x Direction frame is moment frame and the Y Direction frame is simple frame with bracement.
But after the run,beams of moment frame had negligible shear and moment near zero.
the quastion is why?plz help me.
Am I modeling this buiding wrong?plz help.
thanks
thanks
RE: Steel Frame Modeling in Sap 2000
And the base reactions are zero as well?
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
Does the flooring span in the x direction?
If not, how is it supported?
As the moments and shears are low, are the axial forces high?
Michael.
Timing has a lot to do with the outcome of a rain dance.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
