a913 Gr. 65 Steel
a913 Gr. 65 Steel
Looking to find some more information on a913 steel and what exactly is needed for its use in structural steel design. What I've come across so far is a lot of positive talk about cost cutting and it's ability to be welded without a preheating process. But being a quenched and tempered steel will there be a post weld heat treatment needed..will there be any brittle problems that could arise? I also am seeing the wire that would need to be used and the procedures won't be prequalified, am I correct with this? If anyone could direct me to a good article or site that points out both the pros and cons of this type of steel it would be greatly appreciated.
RE: a913 Gr. 65 Steel
Aaron Tanzer
www.lehightesting.com
