Coil Calculation
Coil Calculation
I'm trying to calculate a Coil of Stainless Steel (basically 304) with water vapor at 6bar, the dimensions are DN20 std schedule. Could someone help me with the norm that should I use: ASME, EN or ANSI B31.x?
Thanks in advance!
Thanks in advance!
RE: Coil Calculation
Mike Halloran
Pembroke Pines, FL, USA
Is it in a pressure vessel where ASME could be applied? That might allow others to give you some guidance on what code(s) 'could' apply. Where are you located, that's also another factor.
