Display States in Drawings
So i have been having this problem for awhile and been searching everywhere without luck and I was hoping someone out there could help!
The situation is that I have one master assembly(with various display states) which contains parts and sub assemblies (with their own respective display states.) Now, the only part I am having trouble with is a single part within the master assembly that has 2 display states which is not updating correctly in the drawings. It will go back and forth without notice. When I go into the model, however, and change the display state it works perfectly, in the model, but for some reason is not translating over to the drawings.
This part that I am having trouble with is a separate assembly saved as a part, and the difference in the display states toggles hidden/shown objects within the part. but it WORKS in the model, just not in the drawing.
I'm running SW 2012
Dustin
I'm running SW 2012
Dustin
RE: Display States in Drawings
-Dustin
Professional Engineer
Pretty good with SolidWorks
I never noticed the options before when you save assemblies as parts. I now tried saving "all components" and that has seemed to work so far! really appreciate the fast responses!
CorBlimey-
Thanks for the response, my assembly only had one config originally
