Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is easily the most helpful website I've ever used, and this is the best forum with the quickest response time bar none...."
Geography
Kasian15 (Structural)
28 Mar 12 8:58
I have a building with expansion joints in which 4 sections of the building act seperatly.  Each section has its own diaphragm. In ETABS when the wind loads are placed on the building, is each section/diaphragm loaded from all sides independently or is the wind placed on the overall building.  By placing the load on the overall building it would take into account the EJ and not place wind on the sections adjacent to each other, where in reality there is no wind.
Helpful Member!  slickdeals (Structural)
29 Mar 12 0:48
Each diaphragm is loaded independently. Unfortunately, there is no good way to go about assigning diaphragm loads.
What I have done in the past is to use null area objects on the facade and apply a pressure coefficient (0.8, 0.5 and 0.7) as applicable to (windward, leeward and sidewall).
The ETABS manual explains how to do it.
PicoStruc (Structural)
2 Apr 12 15:15
Don't know if it help.. but i use this procedure to apply accidental torsion on different diaphragm on same story !
1) use Quake/User Load as pattern
2) For the "Modify Loads" window, you can assign load to each diaphragm individually for each story.
asixth (Structural)
4 Apr 12 7:34
Shouldn't they be 4 separate building models to get meaningful results regards to natural frequency and building modes? That's if the 4 structures are independent.
If it was independent diaphragms sharing the same podium I would model as one.
Close Box
Join Eng-Tips® Today!
Join Us             Close
