Equivalent for # 4 polishing
Gentlemen,
Can anybody give me an ISO, EN or DIN surface roughness equivalent for #4 polishing or just the corresponding micron value?
Thanks in advance for your help!
RE: Equivalent for # 4 polishing
Comprehension is not understanding. Understanding is not wisdom. And it is wisdom that gives us the ability to apply what we know, to our real world situations
This Australian article is about the best I've come across.
ht
My question was related to dairy/food purposes, not architectural.
Special finishes 1G (hot rolled) or 2G (cold rolled)
Type of process route: Ground
Notes: Grade of grit or surface finish can be specified. Unidirectional texture, not very reflective.
Special finishes 1J (hot rolled) or 2J (cold rolled)
Type of process route: Brushed or dull polished (one surface only unless otherwise agreed upon at the time of ordering).
Surface finish: Smoother than ground.
Notes: Grade of brush or polishing belt or surface roughness can be specified. Unidirectional texture, not very reflective.
Thing is I'd forgotten where that site was and in the process of looking for it found these.
htt
ht
http://www.bssa.org.uk/topics.php?article=190
http://www.bssa.org.uk/topics.php?article=47
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks for pulling up that cross reference chart. I didn't realize #4 finish had such a wide range meanings, all the way up to 60 Ra (microinch).
Proof yet again advice here is only worth what you pay for it.
