Export jt assembly file from TeamCenter
I read this topic http://www.eng-tips.com/viewthread.cfm?qid=275540, but now I need export a big assembly.
I don't want to open the entire assembly in NX.
Via TC, which is the procedure ?
Thank you...
Using NX 8 and TC8.3
RE: Export jt assembly file from TeamCenter
Cubalibre,
See "%UGII_BASE_DIR%\pvtrans\run_ugtopv.bat" -help
Thank you for the info.
Thank you...
