Integral Weld Neck Flange Design Per ASME VIII, Div 1, Appendix 2
What are the engineering reasons behind the hub slope limitations given in ASME VIII, Div 1, Appendix 2 Fig. 2-4 Sketch 6 for integral flanges?  Is it due to stress concentrations?
Also, is sketch 5 intended to be for an integrally cast flange, where as sketch 6 is for a welded flange?  I am assuming this is the situation because no minimum weld distance from the flange is given in sketch 5.  Apart from weld detail and the slope limitations sketch 5 and 6 look to be equivalent.  Is there a reason not to put a slope on the sketch 5 designs?
Thanks.
