Is the example below a standard (Dim), if so, what is the standard?
Is the example below a standard dimension when using foot and inches?
1'-0"
1'-0"
RE: Is the example below a standard (Dim), if so, what is the standard?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
To write 1' when 1'-0" is meant is ambigious and confusing.
I generally dimension in ft-in on large welded assemblies because the welders use tape measures graduated in, yes, feet and inches.
Mike
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Trying to use common rounding conventions seems questionable.
