BEND FROM EXTRUDED IN SHEET METAL - NX7.5
I've just found out that I can't apply Bend option to an Extruded created solid in Sheet Metal.
I do have a logical explanation of why using Extruded, instead of Tab:
I want te reduce the number of using an additional operation (Cut, Slot, etc) for the final profile I want to create.
I have the feeling that a good designer should create a part using as less feature as possbile.
So, why Extrude option in Sheet Metal, does not accept a bend operation?
RE: BEND FROM EXTRUDED IN SHEET METAL - NX7.5
That is a very simple part, and adding a feature or two won't hurt anything.
You seem to be making a mountain out of a molehill here.
The attached part was just an example.
The job that inspired me for my inguire is much more complex!
But thanks a lot for considerating my request!
then it should work convoluted? yes. Annoying? yes. but that's the way it's done now.
- then you can bend it.
There is no difference between extrusions created in Modeling and Sheet metal, both have to be converted to Sheet Metal.
Tomas
You may want to create the flat pattern and then bend it from there.
Why does it need convincing? is it insecure? why must it think it's sheet metal it's not the only material that bends. nor is sheet metal the only aplication for such bends.
-I have seen a few imported parts that were non-uniform thickness and therefore could not be flattened.
( -I wrote the word "convince" as a joke..
I don't think that you could use other bodies than those that had been created in the Sheet metal Application in NX4, - if you didn't use the old Unigraphics Sheet Metal features, then you probably could bend/ unbend.
The current SM application was introduced in NX3.
Tomas
In my opinion, it should!
Thanks all for your reflection on my topic!
- Sorry for that joke, it wasn't meant to fool anybody.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
It doesn't even accept Flange in Sheet Metal environment!
Presence of Extrude in Sheet metal doesn't seem to be justified!
John R. Baker, P.E.
Industry Sector
Cypress, CA
Regards, / Tomas
Tomas
The forming process itself has too much variation to allow 4 prepunched holes to line up like you show. It could be done if you used a forming block to do it all at once, but it would take some experimenting to get the plate stops just right.
Ben Loosli
John R. Baker, P.E.
Industry Sector
Cypress, CA
