New Pro/E User (redundant save)
Every time I save a file (Using pro/e 5.0) I look and there is a new version of the file. I don't understand why it doesn't just save it over the original instead of making a copy. The two files with the same name are the part as it was save at the moment it was created.
RE: New Pro/E User (redundant save)
There is a batch file called cleanup.bat. Run it in the directory and it will delete all parts except for the one with highest numbered suffix.
Hope that helps,
- J -
BTW, the is a pull down in the file open dialog box that will let you see "all versions" so you can open an older one. Otherwise Pro/E will always get the highest version number.
