Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...you guys have given us a way of asking a question and getting some very timely feedback from other users so we don't have to re-invent the wheel time and again..."
Geography
jayson30 (Mechanical)
27 Mar 12 12:39
i need to find the instantaneous efficiency of the flat-plate collector using hottel-whillier-bliss equation, when the collector is connected to an single-effect absorption chiller (70kw cooling capacity)
i am confused with what will the inlet and outlet temperatures of the collector be?
thanks
willard3 (Mechanical)
28 Mar 12 8:34
Temperatures will relate to insolation. Do you know the insolation rate?
Panel mfg will tabulate temps given this information.
28 Mar 12 13:31
thanks for your reply "willard3"
i have the insolation values
and i'm assuming that the generator inlet temp will be the outlet temp of the fluid from the collector
my question is what will be the inlet temp to the solar collector? is it the case that the outlet temp of the generator is the inlet temp of the solar collector
thanks
29 Mar 12 8:44
You should hire a competent designer.  This purpose of this site is not to do free designs.
You need some basic thermodynamics/fluids/heat transfer which can be had in Engineering school.
Close Box
Join Eng-Tips® Today!
Join Us             Close
