Animation for a fan in UG
I'm new to UG and I'm modeling an assembly of a fan and a shaft, I'd like to make the fan rotate at a constant speed around the shaft but I can't get there.
Can anyone help me with the step to go through to make it?
Thank you all :)
Thank you all :)
RE: Animation for a fan in UG
Assemblies -> Sequence...
...and create a new Sequence, then select the 'fan', and when the handle comes up select the appropriate rotate handle and entire some mulitple of 360°, then select the green checkmark and now you can play your sequence using the red 'VCR' controls in the the Sequence toolbar. And if you're running NX 6.0 or newer, there will also be an icon show a movie camera which will allow you to create an AVI of your fan so that you can play it on any 3rd party media player.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Thanks for the help, I can fina;ly see the fan spinning! Youppi! :)
