Equivalent Loads
Equivalent Loads
Hi All,
Please see attached file. There is a element AB, with a point load at F. The point load has three components (in metric tonnes) in X, Y and Z directions. Can someone advise/calculate the equivalent forces in X, Y and Z directions on points A & B due to the point load F? Thanks in advance.
Subseaocean
Subseaocean
RE: Equivalent Loads
ing. FERRARI Alberto - www.ferrarialberto.it
BA
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
While the load in the Y direction can be found on points A and B, what will be the loads in the X and Z directions on points A and B?
SubseaOcean.
BA
BA
1. Thanks for your comments and please see attached.
2. Please see beam CD, with a load L of 10mT as shown. Is it not that the load in the same directions will be 10 mT each at C and D (or 5 mT each at C and D), irrespective of the distance of the load from each end ? Just have some confusion here.
THanks.
Appreciate all your suggestions. Thanks a lot.
SubseaOcean
