Best solution for liquid brine?
Can you help me about the best solution for a liquid brine application?
Temp: -5ºC
P: 4 bar
RPM: 3000
Single or double cartridge? API PLAN? Faces?
Do we have to consider crystallization?
Temp: -5ºC
P: 4 bar
RPM: 3000
RE: Best solution for liquid brine?
Alternative is a tandem with water buffer fluid. This prevents any potential of crystal build up and saves you running water lines to seal. plan 11+ 52
Note if spring is in contact with product use Hastelloy or Monel not S/S because it will fail due to stress corrosion.
Trust this helps
Generate movement inside the chamber to avoid cristal build?
Cheers
Plan 02 better than 11?
Cheers
