Maglock on existing exit door to building
I had a query with regards to the application of a delayed egress system on existing exit door. The existing exit door to the building is not fire-rated. It has a normal mechanical latch to it. To be compliant to code, do I have to remove the existing mechanical latching device and only use maglock on the exit door or could systems co-exist.
Thank you.
Thank you.
RE: Maglock on existing exit door to building
Bill
"Why not the best?"
Jimmy Carter
