Rotating Object/ Datum plane issue
I am having trouble trying to figure out a way to get the datum planes on pro/e to remain visible when rotating the figure with the middle mouse button. This issue happens anytime I try to rotate the working area. This happens when there is a solid or if it is empty. I can't seem to find an option to keep this from happening can someone give me some advice
RE: Rotating Object/ Datum plane issue
Ben Loosli
Hope that helps,
- J -
View > Display Settings > Model Display > Display While Re-orienting > (check) Datums
For anyone who needs more detailed information!
Yeah like Looslib said the datum hide is to improve performance. This is the same reason that Hidden Line display is not dynamically calculated and the Part Displays all edges in Wireframe while spinning unless you set
FastHLR to Yes
This option can be found on the Environment dialog Tools > Environment
Then all hidden line calculations are done live you'll see edge change to hidden when it goes behind other geometry.
According to SolidWorks for their system showing in Shaded Mode is easier than Wireframe for display purposes.
Ben I was wondering what your thoughts on this were, Or if UGNX handles graphics display similarly.
Michael
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ Shweep
= ProE = SolidWorks
Ben Loosli
