pause after each path manufacturing prefs NX8??
Version after version I have been looking for a setting or customer default to disable this function which stops the toolpath generation after each operation when you regen multiple operations. It seems like a file or session oriented choice.
I would like to always allow NX8 to regen all ops selected always. anyone have any answers?
GL
GL
RE: pause after each path manufacturing prefs NX8??
This is from NX 6, but I can't imagine why it would change.
It's a file oriented choice.
If you edit your template file you can effectively make it a global change for all future parts.
Choose "Preferences>Manufacturing". on the "operation" tab you can set some options.
See attached picture.
NX 6.0.5.3
Have a great day...
GL
In your operation template files, edit each operation then go to options-edit display and turn off pause. Also, if you open old part files and the operations are pausing you can edit those the same way as well.
NX 7.5
Not to be confused with the similar default for Replay.
Mark Rief
Product Manager
Siemens PLM
thanks!
Is this a new option in NX8?
GL
