High Speed Confusion........I am a
High Speed Confusion........I am a mechanical engineer working in the field of electrical interconnections (connectors). Can someone explain in basic terms what the frequecny of operation the following "protocols" run at:
CAT 5
100 Base T Ethernet
1000 Base T Ethernet
IEEE 1394
Mil-Std-1553
Fiber Channel
Any comments are welocme. Thank you in adavcnce.
CAT 5
100 Base T Ethernet
IEEE 1394
Mil-Std-1553
Fiber Channel
William H. Bernhart, P.E.
I work as a development engineer for AMP - Tyco Electronics located near Harrisburg, PA. I help design interconnections and electrical connectors for aerospace applications.
RE: High Speed Confusion........I am a
CAT 5
http://www.advancecabling.com/category.html
ETHERNET, INDUSTRIAL ETHERNET
http://www.ots.utexas.edu/ethernet
http://www.industrialethernet.com
http://ethernet.industrial-networking.com
http://www.industrial-ethernet.com
http://www.ethernetio.com
http://www.transparentfactory.com/technology/herschmann/index.htm
http://www.hirschmann-usa.com/netmain.htm http://www.iaona.com
http://ethereal.zing.org
IEEE 1394
See Firewire
FIREWIRE
http://www.1394ta.org
http://www.andygrove.com/technology/1394/papers.htm
http://www.ti.com/sc/1394
MIL-STD 1553
http://www.sbs-avionics.com
David Baird
dbaird@gemcity.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
100 Base T is fast ethernet, transmitted over Twisted pair cable. It has a raw data rate of 100 Mbits/s and is full duplex
1000 Base T is Gigabit ethernet, over twisted pairs, raw data rate of 1000 Mbits/s and is full duplex
IEEE 1394 is firewire. raw data rate is 400/Mbit/s and up.
Mil-std-1553 is a command/response bus transmitted over a single twisted shielded pair. 1553 is very robust, with emissions controlled to met aircraft EMC requirements. Raw data rate is 1Mbit/s and is half duplex
Fiber Channel is a protocal that can be implemented over either copper wire or fiber. It has variable data rates starting at about 100Mbits/s and going to well above 1000Mbits/s.
