API 2000 - Inbreathing flow: which one?
For sure another person already did this question before, but I couldn't find any!
If one have a (for example) ethanol 5000 m3 tank, on Santos, Brazil, and would like to know the venting required for thermal inbreathing (for filling and emptying there are no problems), three situations arise:
By item 4.3.2.3.3 the venting required would be 2524 Nm3/hr;
By Annex A, table A.3, it will be 787 Nm3/hr;
By Annex F, depending on instrumentation level, it woul be: 252 Nm3/hr, 504 Nm3/hr and 1262 Nm3/hr.
Which one is the correct?
The conditions are the same: horizontal vessel, uninsulated, maximum temperature 48,9 degrees C, etc..
How could it be so different?
I appreciate any tip showing me where I am making the mistake!
Thank you!
Thank you!
RE: API 2000 - Inbreathing flow: which one?
My customer is looking at me in a strange way, as I'm a complete stupid!
I've discussed this with a Protego guy here in Brazil and he said they are choosing valves based on item 4.3.2.3.3.
I misunderstood the question of nitrogen venting: API is only suggesting a value, depending on the level of safety one have on each tank.
Anyway, thanks again.
Boerngen
