How to export 2d (or 3d) sketch coordinates to excel/notepad, macro?
I'm trying to export sketch coordinates to an excel or notepad file, but haven't found a way to do that yet. I haven't seen a solidworks function that does it already, nor did I find one from searching the internet. I've seen that some people may have made a macro to do this in 3d using reference points. I don't really care whether I have to set up reference points or it interprets, but I am curious if anyone has a good way to export those sketch points. I tried one macro I found but the code had an error and I couldn't fix it. I know someone will suggest making a .step file and trying to get the coordinates from that, but the only post I found on that was vague. And searching lines would prove cumbersome for a high number of data points, however if this is the best option I'm certainly not above this. Any help would be greatly appreciated.
RE: How to export 2d (or 3d) sketch coordinates to excel/notepad, macro?
Why not write your own macro?
I think in the API examples there is something to enumerate sketch entities.
But perhaps you could explain in more detail what you are trying to do.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
