concrete tank with checkered plate on top needs to be SEALED
i have a rectangular concrete tank with platform on top.
it needs to be air sealed so vapors dont escape, no pressure on the tank.
what type of seal do you recommend?
RE: concrete tank with checkered plate on top needs to be SEALED
But if you're worried about odors escaping, trapping them might end up deteriorating the concrete and the plate.
we have pipe penetrations inside the platform. we even have manholes inside the checkered platform, but those will be welded to checkered plate - so those penetrations are sealed.
the edges though is my problem. steel to concrete sealant is what i'm looking for.
You have to make sure that whatever you pick doesn't react with whatever fumes you're sealing. So contact the manufacturer to see if they have tests with whatever you're dealing with.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
StoneCold
