Coated CS bolting for cryogenic service
I have spec which reads that for a cryogenic application (design T approx. -325 F), A320 L7 bolts + A194 gr 7 nuts, both PTFE coated, will be used.
From B31.3 (applicable design code), I believe L7 may not be used at that temperature. Environment is inside a building, highly corrosive fluids.
From an application point of view, would anyone suspect a problem?
I have no background in cryo's, but something tells me L7 at -325 F may become too brittle. However I dont know what the PTFE will 'do to it'.
RE: Coated CS bolting for cryogenic service
ASTM A320 requires impact testing of L7 at -150 F, with a minimum energy of 20 ft lbs. Cryogenic applications at -325 almost always use an austenitic stainless steel such as grade B8 from ASTM A320.
Put short, it means L7 wont do the job, and they'll probaly become too brittle and break at some notable event.
Plymouth Tube
For prevention on galling, corrosion, decrease bolt stress, etc.?
Just be aware that many of the coatings also become brittle at cryo temps.
I have seen bolts made of 625 used for service that required the combination of high strength, corrosion resistance, and wide temp range (625 will handle -400F to 1400F).
Plymouth Tube
