Welder testing
Welder testing
Welder testing
Can anyone advise on following?
When testing welder to AWS D1.1 is the material an essential variable. As you are testing the welder skill to use consumable & not material.
RE: Welder testing
D1.1 is only applicable to carbon steel and high strength low alloy steel. Qualification using any of the steels listed in Table 3.1 qualifies the welder for any steel listed in D1.1.
Best regards - Al
RE: Welder testing
Eck, you can see Table 4.12 for essential available whatever you need to care.
