Stress assist mass diffusion analysis
Stress assist Mass diffusion analysis.
To understand, i tried to work out the example problem 8.1.2 in Abaqus example problem manual "Stress analysis with linear elements, followed by a mass diffusion analysis with linear elements".
Initially i did the stress analysis by taking the input file from example " difftocrack_linearstress.inp" and wrote the results to use in mass diffusion analysis in"difftocrack_linearstress.odb" .
Case1:Then i tried to do the stress assist Mass diffusion analysis by taking the example input file "difftocrack_linearmassdiff2.inp" and by defining the predefined field in initial step , category: Mechanical, types for selected step: stresses (step-1, increment 1) from the output database file of stress analysis "difftocrack_linearstress.odb".
Case 2: Then i also tried to do the stress assist Mass diffusion analysis by direct specification of stress predefined field.
For both the case i am getting an error msg : "Analysis input file processor exited with an error".
RE: Stress assist mass diffusion analysis
Do anyone working in Abaqus Mass diffsuion analysis,I am working on stress assist diffusion analysis . Let me know how to give the pressure stress value as input in predefined field: in mass diffusion analysis . looking for reply from some one..
