uses of customization in proe
can u tell me about Customization in Proe
How it is helpful in Modseling Process
Thank You
Thank You
RE: uses of customization in proe
Config.pro file is used for customization your Pro/E configuration such as your start part/assembly template, unit, number of decimal places and many more. Please go thru the help for config file to see various options available under config file
Config.win file is used to customized your screen appearance such as customisation of toolbars, adding mapkeys to standard toolbar, editing mapkeys grahical representation and many more..
By setting these things at once, you are not required to set all those again and again. When ever you start your Pro/E session, you can get your customized Pro/E environment.
For this it is required to keep your config.pro and config.win file in your Pro/E start directory.
Hope this will help you.
Yogesh
http://www.geocities.com/edwinmuirhead/pro-how/admin.htm
Ed
http://www.fawcett.com/index.php
You have to join but at no cost to view/download the files
Will give you a colourmap configwin lights and model tree configs.
