NX8.0.1 Titleblock: referenced objects have been deleted or suppressed
In drafting, upon starting a new Drawing using the pre-packaged Siemens template (referencing an existing part), I always seem to get this error pop-up message immediately after creating the drawing:
"referenced objects have been deleted or suppressed"
After clicking "OK", NX8 proceeds to show me the "Populate Title Block" window asking for date, name, etc.
I have an idea as to why the error is coming up, but has anyone figured out exactly why this occurs and what, if anything, should be done to stop it?
Thanks in advance.
RE: NX8.0.1 Titleblock: referenced objects have been deleted or suppressed
Fixed in 8.0.2
NX5, NX6, NX7.5 and NX8
I-deas 12, NX I-deas6.1m1
Solid Works 2009 and 2012
When will NX8.0.2 be available for download?
We got the 'last' delta over the weekend so they will now start the process of verifying the code and running the final acceptance tests.  Then the release letter will be updated and everything will get packaged-up and turned over to software distribution.  You should see something by the end of April.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
