ug post saving issue
I was trying to make a xzc mill-turn UG post,and I found one in default folder called "mill-turn side spindle", and it works well but need some minor changes, in order to keep the original I did "save as", but the new post's result changed totally, and I did not change anything. I have tried V6.0 7.5 & 8.0 NO LUCK, how can fix this.
RE: ug post saving issue
Probably written in an older version of PB. Open the pui file in a text editor and look at the original version of it.
