Explicit Dynamic model
I am running a dynamic model, but I obtain the following error when I apply a concerntrated load on a node, however I am obtaining the following error message:
The ratio of deformation speed to wave speed exceeds 1.000 in at least one element. I assume this element is related to the node I am applying the concerntrated load to.
When I apply a displacement to a number of nodes, this problem does not occur.
Does anyone have any suggestions on how to get around this? Thanks.
RE: Explicit Dynamic model
Any input would be much appreciated, thanks.
Point loading is generally a bad idea because of errors like this.  That being said if you ramp the load it should probably converge better.  I usually would model the indentor and apply a displacement load to the far side of the indentor.  I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
Thanks Rob,
"I usually would model the indentor and apply a displacement load to the far side of the indentor"
Could you please expand a little on this, I am not sure what you mean by this. Thanks.
Model the indentor with solid elements.  Apply a displacement to the back surface of the indentor.  Basically move the constraint assumptions away from the area of interest.  I hope this helps.
Rob Stupplebeen
