Using Washers to Increase Thickness
The supplied fasteners are A490 bolts used in slip critical connections. The bolts are too long and the contractor is intending to include washers to build up the 1" distance. Is there any technical reason for not permitting this?
Dik
Dik
RE: Using Washers to Increase Thickness
There are reasons to not use washers to make a spacer ie:-
1/ It effects the friction coefficient of the joint, which can
change the bolt preload on tightening.
2/Alters the stiffness of the joint.
I'll post with some lnks shortly
I have seen conditions with 2 or 3 washers. But 6-7, 5/32 washers sounds excessive.
http://www.FerrellEngineering.com
http://www.wds.com.au/pdf/why_use_flanged_nut.pdf
Of course it was a facetious comment being a structural engineering office.
