Assembly fitting (tungsten carbide into a steel)
Hi everyone,
i'm a Portuguese student and i work as a engineer, i want to know if someono can help with some information (stresses, assembly fits equation) related to assembly fitting. assembly fitting refers to a carbide that is mounted into a steel case (like a die for extruding). If someone could help me.
Rui Pacheco
RE: Assembly fitting (tungsten carbide into a steel)
I can probably help you.
The more information you could give me the better I could help you.
I assume you are talking about brazing carbide into a die. Typically the steel grows so much more than the carbide that it leaves a gap between the carbide and the steel so big that you don't get wetting on both sides.  I often recommend pre-positioning the braze alloy and flux below the carbide part then heating until the carbide part settles down. This will leave a gap between the carbide and the steel. You can then go back and fill this gap from above although this is generally an appearance issue and not very often a functional issue.
I like a 49% silver braze alloy with manganese. I like to see at least 0.005" all the way around the carbide including underneath.  This increases stress relief and provides good impact resistance.
I prefer dumping little braze alloy bits down the hole and letting the braze alloy flow and wick.  I do not like playing with tri-metal foil for a variety reasons but mostly cost and effectiveness.
Sincerely,
Tom Walz
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
