Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I've learned more from your forums in 3 days than 3 months at school and on the job combined..."
Geography
VTengr (Structural)
24 Mar 12 7:29
Hopefully this is an easy one.
In Risa Floor I have a situation where I've applied area loads to a floor, but now wish to delete them.  Using the graphical editor, I try to delete them by clicking in the area, but it doesn't delete.  Nothing happens.
I've experienced a similar situation with applied decks.
Any suggestions?
JoshPlum (Structural)
26 Mar 12 15:50
It should be pretty easy to delete them.  However, keep in mind that you cannot delete the "drawn in" deck or area load.  This is defined on the Floors spreadsheet.
In the plot options, you have the ability to view the deck and area loads "as input" with or without the defaults shown / displayed.  So, you might take a look at those plot options to see if that's what your problem is.
Every now and then I will see a user defined area load or deck polygon which has gotten corrupted somehow (and cannot easily be deleted or modified).  If that has happened, I would suggest sending the model into the RISA tech support group (support@risatech.com) as there are still tricks that we can use to get rid of the corrupted data.... usually.
VTengr (Structural)
27 Apr 12 8:59
Josh-  I forgot to thank you for the reply.  It was corrupted.  Before I tried in a different model, I thought I was going nuts!!
Close Box
Join Eng-Tips® Today!
Join Us             Close
