Evaluation of Stress Corrosion Cracks in Pipelines
ASME 31G for the evaluation of "the remaining strength of corroded pipelines" but it is not used for crack like defects.
What code can I use as a reference for the evaluation of Stress corrosion cracks in pipelines under pressure?
Thank you
Thank you
RE: Evaluation of Stress Corrosion Cracks in Pipelines
ASME G103 might help
http://www.astm.org/Standards/G103.htm
with some additionl hints here,
http://www.npl.co.uk/upload/pdf/stress.pdf
From "BigInch's Extremely simple theory of everything."
SCC crack growth is a bit like buckling, lightning or earthquakes. it is not something you can put a number on when it comes and bites you.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
