Slender Concrete Column Design AS3600
Hi Guys
Does anyone have any tricks for designing slender concrete columns where the Le/r ratio starts getting higher than 50.
I am noticing a large fall away in strength for columns with high Le/r.
Does anyone know how to reduce the effective length factor, I normally use a ke=0.85 for braced columns and sometimes get it down to 0.8 by calculating buckling effective lengths in FE packages. I haven't explored too much into the graphs used in AS3600 for the calculation of effective length factors.
Does anyone have a good justification to not consider the minimum eccentricity provisions of AS3600?
I have attached the 2 column design curves for an 800x300 column for Le/r's of 25 and 60. I have walked passed many columns thru the city which are very slender so I am looking for a way to push my columns skinnier.
Thanks and regards
Thanks and regards
RE: Slender Concrete Column Design AS3600
2. Can you brace it at mid height? Perhaps a couple of CHS braces would work without being too obvious.
Better to sleep well at night.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
