Pump selection
Pump selection
can anyone recommend on th pump that can be able to pump MR fluids
RE: Pump selection
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Pump selection
MR is MagnetoRheological fluid?
Is it an industrial application, laboratory or research service?
If you have differents rheograms vs magnetic field intensity
and you have magnetic field intensity in your service and
evaluated shear stress is below 100 Pa, you should use centrifugal pump, if it is higher you should use positive displacement pump.
Since MR is a Non-Newtonian fluid, you should take care in calculation loss of pressure, corrections pump factors, etc., and take in mind that conventional correlations of fluids does not apply on this kind of fluid.
I Hope Its Helps
RE: Pump selection
O.k. What pump? That depends upon flow and expected pressure. But gear pumps, peristaltic pumps or progressive cavity pumps seem to be options.
