Small stainless steel for my application
I need a Small spherical stainless steel for my application, Diameter about 40 mm and weight about 25 g. Do you know some supplier ?
Thanks for your contribution
RE: Small stainless steel for my application
It will need to be hollow.
Good luck,
Latexman
yes hollow and welded.
Search for "hollow stainless steel balls", "hollow metal balls" or "hollow balls". You get a lot of hits in Google.
This has been a fascinating and informative thread....
Use GOOGLE you say......  HHhmmmmmmmmm..!
