tethered structural washers
I'm looking for washers that have a tab and hole similar to the one shown in the attached picture of ordnance fastened with structural bolts used with tethered washers. They need to be structural and anti-corrosion coated.
Once I source the washer, I need to determine a method of keeping the bolt and washer from separating, while still allowing free rotation.
Thanks for the help
RE: tethered structural washers
Has anyone ever used electrical ring terminal connectors for this purpose? If only I could find one made of aluminum, not nickel plated copper.
