Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...this web site is a 'Godsend' for me. If I have a programming problem that I'm unable to solve, I'll get a sensible reply in no time. It's really great!..."
Geography
The cost effective way for energy submetering?
scythe13 (Mechanical)
22 Mar 12 14:21
Because heat meters are so expensive, what are the alternative ways to calculate the energy consumption of fan coils?
-consider the pipe distribution is horizontal, so by knowing the flow and supply and return temperature I can estimate the energy consumption.
-The flow in fan coils are constant, the adjusting parameter is fan speed, so I just need to measure the flow annually
-What I have in mind is setting thermometer in the inlet and outlet of pipes. The thermometers record the temperatures hourly, then at the end of each month I can collect data remotely and export them into an excel spreadsheet.  Can you give me a link containing datasheet of such thermometers?
walkes (Mechanical)
23 Mar 12 8:34
Any controls company should have what you need.  A pipe-mounted DDC temperature sensor.
Try the Honeywell website
http://sensing.honeywell.com/products/temperature_sensors?Ne=2308&N=3185
Drazen (Mechanical)
23 Mar 12 8:48
Currently, Grundfoss presented new generation of pumps that also have heat metering option regularly included.
This is one of improvements I deem very useful, as each and every pump will have such option at no additional charge, and lot of opportunity for energy monitoring and management can be open.
Of course, that applies only for new installations or large refurbishments.
MintJulep (Mechanical)
23 Mar 12 11:01
If I were a tenant and a landlord proposed to send me an energy bill calculated from hourly temperature measurements and annual flow measurements I would not lease in that building.
Or I would lease, then refuse to pay the energy bill because the proposed method is not sufficiently accurate.
There is a reason that proper heat meters cost money.
If this is for purely internal auditing then it might be ok.
Close Box
Join Eng-Tips® Today!
Join Us             Close
