Question regarding constraints for advanced simulation
I am trying to do a simple crash test simulation (I am constraining the Z axis of the vehicle and applying a force to the 'front bumper') in UGS 7.5.
Whenever I run the simulation the front bumper doesn't interact with the rest of the vehicle, it just goes through.  I think I need to constrain the bumper to the frame.  I tried to use a 'automatic couple' and 'manual couple constraint' and then solve the simulation, but then I can't view any of the images from the simulation because an error message comes up that says
"Error recovery completed for the following error: Internal error: memory access violation".
If I then delete the constraint and solve it again, the error goes away, so its a problem with the constraint I guess.
Am I going about this the wrong way?  is this the correct constraint to be using, and if so how do you properly use it?
I have attached an image of the simulation before I tried using the couple constraint.
