Elliptic fillets?
Elliptic fillets?
Elliptic fillets?
What function does one use to create elliptical fillets?
RE: Elliptic fillets?
This depends on your license, most people should have it access to it though. It will be found in Part Design, use the Fillet command and there is an option "Conic parameter" which allows you control over the sharpness of the fillet by adjusting a Rho value, this determines the sharpness of the ellipse.
Is this what you were after?
Certified SolidWorks Professional
