BOM Crashing my Drawings
I am working on making some exploded assembly drawings but when I add a BOM I cannot reopen the drawing.
I will go through and make the drawing with no problems.  I can save it in SW and other formats with no problems.  But, when I close the drawing I can no longer open the SW drawing.  I can still open them if I save them as a PDF or such.  I can even open the SW drawings in eDrawings.
I see the file in the folder but if I try to open it form there or go File > Open in SW nothing happens.  If I try to make a drawing from the assembly I am told that one already exist but when I try to open it that way I get a message that I don't have write access but nothing happens when I try to open it as read-only.
I have narrowed the cause of this problem down to when I add a BOM to the drawing.  Anyone have any ideas how I can fix this?
-Anthony
RE: BOM Crashing my Drawings
What version of SolidWorks are you using?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Solidworks Premium 2011
Service Pack 3.0
Try opening the drawing in Quick View mode, and then right-click on the sheet or sheet tab and select Load Sheet
Which BOM are you adding.  If Excel, there could be something with Office?
check your microsoft settings.
  I had a similar problem with Alibre and found I had inadverently checked a box making the files protected.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
