Problems with mesh mating conditions in NX
Lately i have been trying to solve some fairly large assemblies in NX 7.0 using mesh mating conditions between joints, however whenever i try to solve i get this error message:
DOF 1 of node 188323 is set as dependent by element 191646 in mesh "auto_mmc_3_mesh" and
by element 188438 in mesh "partition_3_mesh".
SUGGESTION: Set parameter "AUTOMPC" to "YES" in the "Edit Solution..." dialog.
I have done the suggestion NX suggests in the edit solution tabs, however the model does not solve.  The other alternative is to use contact meshes but i do not think they are very accurate any help would be appreciated
Many thanks
