NX 7.5 Wavelink Creating new parts
I have the following parts modeled in NX
1. PRT file with Raw material cast iron with a master drafting drawing.
2. PRT file with wave link back to File 1 cast iron with machining subtract cut features to the wave link solid body of the cast iron part with a master drafting drawing.
3. PRT file assembly which I used for the Wavelink that contains parts 1 and 2.
Now I want new items of all files and to keep my Wavelinks and drawings attached in the new files like they where in the original file.
I want the wave link to be with the new cast iron raw material to the new cast iron machining.
We are using teamcenter.
What is the proper steps or did I mess this entire process up? Do I have to delete the Wavelinks and recreate them?
Is there a better process?
RE: NX 7.5 Wavelink Creating new parts
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
When you do the save-as, TC should ask you if you want a new revision, item, etc.
www.nxjournaling.com
h
John R. Baker, P.E.
Industry Sector
Cypress, CA
When we have a design and want to use it as a starting point for a new design we use clone assembly.
Jurgen Kreisel
Weber Manufacturing Technologies Inc.
