LNG lines Supporting
Dear Friends,
Do you know a good guide book for crygenic lines supporting(such as LNG lines)?
I need to know rules of crygenic lines.
tnx
RE: LNG lines Supporting
You must have no direct metal-to-metal contact between the line (pipe) and the Support.
1). Check with your Insulation Vendor for "High-Density" Insulation.
2). Check with Support Vendors for "Clamp-On" Supports with non-metallic elements between the pipe clamp and the support plate.
Thank you Pennpiper.
Are not existing any guide book?
Have a look at Torgy or Atlantic Supports websites, both do cryogenic supports for pipes and vessels.
