Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for creating this site - I expect to be visiting it often as I continue to try to grow my bag of tricks!..."
Geography
Mony85 (Automotive)
21 Mar 12 9:41
I'm a new user of FEMAP v10.3.1 and I would like to select plate elements "by face" like I do in Hypermesh (selecting one element of a face, hitting "by face" and then having all the elements of the face automatically selected).
On FEMAP I've found some kind of "by face" selection tool by following the path "entity selection > pick^", but I'm unable to select anything by using this function.
I would be grateful is someone could help me regarding that!
Mony
rb1957 (Aerospace)
21 Mar 12 11:08
without looking at FeMap (i have used it, just not where i am right now) i think you can make a group by selecting elements by PID (for plates) and (expecting that the same PID is used for more elements than you want right now) then select the elements using a "picking box" ... if that's not clear look up the manual for methods to select entities (you're looking to pick all elements within a box drawn by the cursor).
have you tried the help desk ?
dwallace1971 (Aerospace)
22 Mar 12 8:37
When you say, "by face" do you mean geometric face?  If so, you can use "Method" selector in the select dialog box to "select by surface", then click on a surface.  All elements associated with the surface will be selected.  If your elements aren't associated with a surface, this won't work.
I hope this helps!
AlRobertson (Mechanical)
26 Mar 12 19:54
When you are in the element Entity Selection dialog, click on the Pick ^ button and select By Faces... and a second Entity Selection dialog appears. Select the general group of elements that includes the subset of elements you eventually want to end up with, and click OK. Then in the subsequent Face Selection dialog, click Adjacent Faces, and pick one of the desired element faces, and click OK. Back in the first Entity Selection dialog you can highlight what you've selected by clicking on the highlight button. If you are happy with the selection, click OK again.
Note that in the Face Select dialog there is an angle tolerance that controls what Femap considers to be the adjacent element plane from element to element. The default is 20 degrees, so if you want Femap to include elements around less acute angles in the model, but not right angles say, then set the tolerance to be something slightly less than 90 degrees.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
