getting solid data into CatiaV5 from NX without Catia step translator
Our company opted not to buy the step translator for Catia. When I import Iges files all I get is trimmed surfaces. any ideas on how to get solids into CatiaV5 R18?
RE: getting solid data into CatiaV5 from NX without Catia step translator
Unfortunately, the only advice I could offer is to look into a 3rd party company who could make the data translation for you. A word of warning, though - I did the same thing with a project I was on 2 years ago, and the original NX data, after being STPed out and imported into Catia using the STP translator, still consisted of all surfaces - Catia could not close the surfaces, and therefore could not create a solid geometry. So, depending on the complexity of the NX data, getting solid geometry in Catia without a specialized healing module (more $$$) may not be possible (just my experience).
We used to have a step translator for Catia and that worked just fine, we just are forced to use iges now. maybe an intermediate program like Pro-E or solidworks can make a better iges file and actually return solids? I have those two programs and need to try on some files, unless someone else has already had some luck getting from NX to Catia without step somehow that they could share.
Or any luck using iges period to get solids?
FXjohn,
       There is an option in Catia for this.  I just tested with our data admin's NX seat.
Tools - Options - General - Compatibility - Iges.  Join surfaces of the model.  I also use advanced optimization  - deform .001  Angle 2 with Topological reduction of boundaries.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Thank you Derek, I also found that step to Pro-E to Iges also works
FXj
