Does Draftsight comes with eTransmittal or similiar commands?
Hi all,
I have been trying to search for this command within draftsight.
But my search has not been successful.
Any kind souls want to help me out?
Cheers
Kevin
Cheers
Kevin
RE: Does Draftsight comes with eTransmittal or similiar commands?
Since there is no such command in AutoCAD, why would you expect to find it in Draftsight?
Mike Halloran
Pembroke Pines, FL, USA
Thanks for your respsonse.
You are right about eTransmittal is a forwarding service.
It was a typo error as what I'm asking is eTransmit not eTransmittal.
My bad.
Sorry about that.
Anyway, any solutions?
Please?
Cheers
Kevin
You may be refering to the edrawings command or File>Publish eDrawings. It might work for you. You can look up eDrawings in the help files and there is an explanation there.
In the Help file it says:
"The eDrawings command starts the eDrawings® application which gives you the power to create, view, and share 3D models and 2D drawings."
the "share" part might be useful.
Frank Reid
One test is worth a thousand expert opinions. - Dan Joos, test engineer
