Sketch Driven Pattern
I cannot find a satisfactory explanation of the difference between the Reference point options in the Sketch Driven Pattern Property Manager.
Centroid
Selected Point
Please explain. This is time sensitive, so a quick response will be greatly appreciated.
TIA,battle
Centroid
Selected Point
TIA,battle
RE: Sketch Driven Pattern
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
See the images after point 9.
Can someone state it explicitly,clearly?
For cylindrical, conical, or revolved features, the centroid is the intersection of the axis of revolution with the X-Y plane of the pattern.
If the sketch consists of lines and arcs, such as rectangles or oval shapes, and if the sketch plane is parallel to the X-Y plane, the centroid is defined as the centroid of the sketch.
For any other condition, the centroid is the centroid of the face of the seed feature.
If there is more than one seed feature, the centroid of the first seed feature is used.
If the seed feature is generated from a sketch that includes multiple contours, the centroid of the largest closed contour is used.
Dan
www.eltronresearch.com
Dan's Blog
