SolidWorks and SolidEdge to SVG?
All,
I need to be able to export SolidWorks and SolidEdge files to vector graphics such as SVG.
It appears that can't be done natively.  How can I do it?
Thanks so much!!
RE: SolidWorks and SolidEdge to SVG?
You will need Adobe Illustrator, or CorelDraw, or similar.  There seems to be a opensource program called Inkscape that can also do this file conversion.  It also seems that Win2PDF program ($35 for 60-day trial) can also create SVG files.  I've never had to create them.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
