TSHH( Very High temperature discharge compressor shutdown switch)
Hi!
Why do they make a TSHH for centrifugal compressor?
Many thanks
Many thanks
RE: TSHH( Very High temperature discharge compressor shutdown switch)
I know it's preventing it from damage, but could you explain to me how?
Thanks for your replies
I thought first about the head (power per volumetric or massic unit), What is the max. of head supported by compressor?
Because the temperature is about 120°C.So, Could the temperature causing thermal damage be the reason of TSHH and not the problem of the head which is directly related to the temperature?
Many thanks
also what is stated by geordie87 could be a vlid reason.
Usually, there is three TT location around the centrifugal compressor. One is
Located in the inlet line of compressor suction drum, the other is located in the compressor discharge line, and the last is located in the after-cooler of
the compressor discharge line.
If the compressor discharges TT got higher temperature, the compressor inlet
control valve will decrease the suction gas into the compressor.
